Help Samsung galaxy note 10.1
stephiey3
Hi,
I don't really know how this works, so hopefully I'm posting in the right area :confused:
I would just like to know if it is possible when using a Samsung galaxy note 10.1 tablet to download a pdf document and then make notes on the document and save it?
Thanks
Welcome to the forums, Stephiey! :hello:
I know this is definitely possible, however I'm not familiar with the Note 10.1 so I'll move it to its forum for the right answer. :)
Try the app iannotate pdf. Used it the other day to sign a pdf document, save, and then return signed document to the sender.
Yes can definitely do with Polaris office that comes on the tablet, or can download a number of apps to do so. The annoying thing about Polaris is unless I'm missing something there is not a simple way to rotate the pdf file. So if you have your tablet orientation landscape and the pdf is portrait, it doesn't fill the screen. You zoom in and out to view everything just fine, just a little annoying.
A note though, some printers require a flat file, so modified pdf files may not print correctly.
