Samsung Galaxy Note 2 Screen on when s pen detached
scanman
If I'm not mistaken prior to the update to 4.3 the screen would turn on. After the update the screen does not turn on after the S pen is detached. The screen does not turn on if I have "open pop up note" checked either )SETTINGS|S PEN|OPEN POP UP NOTE).
Is this behavior found on everyone's Note 2 or is mine just real special?
I'm still on 4.1.2...When I remove s pen. Yes, screen comes on and s note pops up. Did they remove this too on 4.3? Yuck..
I'm running stock 4.3 and there is an issue with the S Pen removal turning on the screen.
Here are the scenarios I have tried and was able to replicate time and again (I use PIN for my lock screen).
With the screen off:
1) If in lockscreen mode with PIN enabled: removal of S Pen will turn on screen.
2) If NOT in lockscreen mode and just on a homescreen: removal of S Pen will make the removal sound but will NOT turn on the screen.
This seems to be a bug with the 4.3 update. Don't think Samsung will do anything about it and expect the Note 2 to have reached EOL in terms of support.
