"According to the latest reports" - sounds like made-up hokum to me.
The Galaxy Note 3 will be available only in Marble White. A sister device without phone capabilities will be available in Titanium Gray and be sold as the Galaxy Tab Mini.
I'd rather have a smaller phone with the same size screen, than a bigger one or even one the same size with a bigger screen.
As it is, I can almost use it great one handed; the top half-inch or so of the display is just out of thumbs reach.
I believe that they are putting out a 6.3" device, but I don't think it will be the Note 3. The Note 3 is likely going to be 5.8" with Razr M like edge to edge screen. This 6.3" phone will be a whole other line.
The first point here is the reason I think the second might have merit and the rumor might be mostly false. If the Note were to remain one hand usable to the degree the current one is you would need a different device for the bigger size.
If you add a size though I think you goto 7" or so and drop the ear speaker in favor of headset or speakerphone use only to save on overall size and pocketability. 6.3" will be too big for one handed use and a bit silly looking up next to the noggin also, but not really into a size realm that really starts to change current pocket options the current Note's fit. I think you may as well goto 7" near bezelless if this pocket size thing is the biggest driver.
Then You'll LOVE this!YES!!!!! bigger is better
I won't be able to hold it![]()
