Samsung Galaxy S GT-S7562 DUOS
Lks Lks
attachment.php
GENERAL
2G Network GSM 850 / 900 / 1800 / 1900 - SIM 1 & SIM 2
3G Network HSDPA 900 / 2100 - SIM 1 & SIM 2
SIM Dual SIM (Mini-SIM, dual stand-by)
Announced 2012, July
Status Available. Released 2012, September
BODY Dimension 121.5 x 63.1 x 10.5 mm (4.78 x 2.48 x 0.41 in)
Weight 120 g (4.23 oz)
DISPLAY Type TFT capacitive touchscreen, 16M colors
Size 480 x 800 pixels, 4.0 inches (~233 ppi pixel density)
Multitouch Yes
SOUND Alert types Vibration, MP3, WAV ringtones
Loudspeaker Yes
3.5mm jack Yes
MEMORY Card slot microSD, up to 32 GB
Internal 4 GB (1.8 GB user available), 768 MB RAM
DATA GPRS Yes
EDGE Yes
Speed HSDPA, 7.2 Mbps; HSUPA, 5.76 Mbps
WLAN Wi-Fi 802.11 b/g/n, Wi-Fi hotspot
Bluetooth Yes, v3.0 with A2DP
USB Yes, microUSB v2.0
CAMERA Primary 5 MP, 2592х1944 pixels, autofocus, LED flash
Features Geo-tagging
Video Yes, VGA@30fps
Secondary Yes, VGA
FEATURES OS Android OS, v4.0 (Ice Cream Sandwich), upgradable to v4.1 (Jelly Bean)
Chipset Qualcomm MSM7227A Snapdragon
CPU 1 GHz Cortex-A5
GPU Adreno 200
Sensors Accelerometer, proximity, compass
Messaging SMS (threaded view), MMS, Email, Push Email
Browser HTML, Adobe Flash Lite
Radio Stereo FM radio with RDS
GPS Yes, with A-GPS support
Java Yes, via Java MIDP emulator
COLORS
White, Black, La Fleur
- SNS integration
- MP4/H.263/H.264/WMV player
- MP3/eAAC+/WMA/WAV player
- Organizer
- Document viewer
- Voice memo/dial
- Predictive text input
BATTERY
Li-Ion 1500 mAh battery
Stand-by Up to 445 h (2G) / Up to 330 h (3G)
Talk time Up to 13 h (2G) / Up to 7 h 25 min (3G)
MISC SAR US 0.27 W/kg (head) 0.65 W/kg (body)
SAR EU 0.47 W/kg (head)
TESTS Display Contrast ratio: 964 (nominal) / 1.400:1 (sunlight)
Loudspeaker Voice 61dB / Noise 60dB / Ring 65dB
Audio quality Noise -81.6dB / Crosstalk -80.5dB
Camera Photo
Battery life Endurance rating 43h
Why I lose GPS signal when i activate both SIMS ???!!!
But when I disactivate one of them I get it...
Could you please help me find a solution to this problem? Thanks in advance.:confused:
hi and welcome:) before post your problems please see your posting in right place or not.. you can make a new thread for your proper solution..;)
GPS needs internet connection, and only one sim internet will be activate for mobile and GPS ..:) it may be something interfacing your both sim card while using GPS, try to update firmware from Samsung Kies and try it again if not fix than report bug to Samsung support.
Hi Androman.......I am so sorry to post my problem here in your thread........this is because i'm a newbie....:o
thanks for your reply...:)
Apps cannot be moved on to the SD card.
Is this a problem with this phone model or the OS?
Can the OS be upgraded to the latest? If yes, how?
Thank you
:confused:
hei friends i have rooted my samsung s duos and by mistake formatted by s.d card and the original back-up got deleted can any1 of u gimmi the original backup of gt7562 so that i can un-root my phone..need it badly
I am planning to get this phone but i am worried as lots of people have complained this phone lags very much.Also no JB update from Samsung.
I bought this phone based on it's features, which were pretty good. One thing I did not do was research before buying it. My worst mistake. It lags like hell!:mad: Even after rooting and overclocking it to 1.3 Ghz. My advice, if you wanna buy from samsung, buy its higher end phones. But not this one.
Hi am anuj i facing one problem with And os in my S7562. I am able to connect wifi successfully but it goes with any browser only. No other apps i am able to play which needs internet through wifi. These apps are not getting connected with wifi proxy server.
Can any one tell me some script or some other solution ?
