Are you running gingerbread (2.3.6), ICS (4.0.4)or Jellybean(4.1)? In ICS it's under menu>settings in the networking area select more. There should be a checkbox to enable NFC
I thought the update from AT&T came as an over the air (OTA) installation. I never did it as I was rooted running ICS long before the official version was released.
Mines sgh-s959g on straight talk, it said an ota update was available but it won't connect to the servers to initiate the download. Would anyone of u know how to get this to work?
The update for the GSII was never OTA. You have to connect your phone to your PC and run the Samsung Kies software. The update comes to your PC and then you update your phone via your PC.
No, sorry. Have you tried going to an AT&T store? They might be able to upgrade it for you.
Well i talked to them and all they said was what i already know. They said I couldn't get it done there and to try a different data cable. Just want ics bad and can't get it done knowing there's an upgrade for this device:banghead:
You're not going to get it through Straight Talk.
Straight Talk and TracFone have never issued software updates to any phone they've offered on their service and they've intentionally prevented this phone from connecting to Kies by not inluding the Kies service in this phone's firmware.
Your only option is to return it and get a different phone or root the phone (possible) and then install a custom ROM (not possible).
At the moment, it's not possible to install a custom recovery image on this phone, nor is there a copy of the stock firmware floating around, nor is there any custom firmware that actually supports the device. And the chances of any of those happening in the future is slim.
Thanks but why do you say anything root related probably won't happen on this device?
Because it's a TracFone/Straight Talk/Net10 device and it's a relatively expensive one. What's the point in the modding scene supporting this device when the number of people using it compared to other phones is so miniscule?
I don't think any other of their other Android devices can install custom firmware yet either, and at least a couple of them have been in the wild for over a year.
When did you get the phone? I got mine maybe three weeks ago, if that, and when I activated it there were no updates available and there haven't been any since. I'm wondering if maybe it's showing an update that's not really there - a bug of some sort.
For me personally, I've made Gingerbread more tolerable by rooting (it's possible using the AT&T SGH-I777 method, Google it, you just can't install CWM recovery afterward and therefore can't install Cyanomod) and using Holo Launcher (implements the ICS launcher in Gingerbread). All of that is like giving morphine to a somebody who just got their legs blown off though. It helps a bit, but it doesn't solve the core problem.
I don't really think you have any other option than returning and getting a different phone (not from ST or TF) if ICS or JB is a must. =/
Yea there in the pull down in the notification I googled and I guess its called spam from some apps and keeps popping up like 3 times a day seems like
