Scousefire
Hi Guys,
I have had my Galaxy S2 for around five days (my first smart/android phone) and need a bit of advice on the battery.
I make a few calls through days, send a few texts and check facebook and then when I go to bed I leave the phone on charge (normally between 11pm and 7.30am), but even without heavy use, I find the battery is down to around 30% by 7pm, and by 9pm its practically flat.
I have adjusted the brightness of the screen, turned off my bluetooth and Wifii but what other advice can you give to extend the battery life?
I have heard that it sometimes takes a while to condition the battery? How long should that normally take? Also, is it worth downloading any apps which can help?
