Samsung Galaxy S2 - Deleted gowidget note
Hi, I'm Missy. I accidently deleted a gowidget note from my phone and was hoping to get it back. Anyone have any ideas where deleted sticky's or notes go if they are accidently x's out?
Thanks,
Missy
Hi Missy,
Glad to have ya! Personally, I don't know anything about that app, but hopefully you'll get the assistance needed.
Good luck. And thanks for joining. :)
Welcome to AF Missy :ciao:
I haven't used go widget note before, but have you tried scouring through your sd card with a file explorer like es file explorer for a folder possibly called go widget or something like that? It's a possibility the note may have gotten saved into that folder.
Hope this helps you. If you have any other questions, don't hesitate to ask. :)
