samsung galaxy s2
jode
could someone help me please.
I've just switched phones and gone for a smart phone for the 1st time. yes I'm a tech dummy and smartphone virgin !!
i have no idea how to transfer all my 'outlook' contacts (email details) onto my phone.
I would also like to transfer all my old phone contact details from my old nokia to my galaxy s2 but again not sure ???
would appreciate any correct advice to put me on the right track please.
You should be able to export your outlook contact into a csv and then import that into Gmail. That will keep them backed up for Android. I hope this helps and welcome to AF:)
like I said never did this before I'm trying my best I guess write it all down on the old one then put it in the new one
what he said. don't worry about what csv is, you should see the option in outlook for export and for import in gmail. That should get the contacts moved over.
i'm trying this now ???
wish me luck
didn't work... or i didn't do it right
how does anyone with a smartphone transfer all there contacts details over.. it can't be the old way of manually entering in all the info again ?
:rolleyes:
You won't need to do that. Sorry if my post were kind of sarcastic. That wasn't my intent. I try to keep my posts lighthearted but in re-reading them they don't look that way to me. I am going to bed shortly but I am subscribed to this thread, so if you do not have help by the morning, I will get you step by steps in the morning.
Again, sorry if I was untoward, I re-read them and I didn't like the tone. I am really here to help. I really like this site as everyone here is helpful and I wouldn't want to be the nitwit to offend you and make you look somewhere else.
i have my microsoft outlook window open..
file - export and import wizard...
then i get confused ???
Open Outlook.
Open the Contacts view.
File/Import and Export.... Export to a file.
Choose "Comma separated values (Windows)".
Select the correct Contacts folder.
Choose the destination and name to save the file to.
Now open Gmail in your desktop browser.
Click "Gmail" in the top-left (with the little arrow next to it) and change it to "Contacts".
Clcik the "More..." button and choose "Import..."
Browse to the .csv file you saved above then click the "Import" button.
Your contacts will appear in Gmail and can be edited if required.
The next time your Galaxy S2 syncs with Google, your contacts will magically appear! :)
I hope this is easy to follow.
