That's is weird, I'll have to try and tempt a salesman to demo with sandpaper next time lol, cheers for the info, does that mean if I put the card in my pc and rename it to say mIggs' card will work?
What you name the SD card is irrelevant to the operation of the SD card. Computers (Linux/Android, Windows, etc) can associate names with storage devices. The name may not show up on the GS3, but all of the data will be there.
	One thing I don't get with this high end phone:
Samsung make this high end phone to, in effect, go against iPhone and other leading smartphones and they don't even bother to make a pc/mac software to go with it. I am struggling to transfer files to my galaxy as my Mac cannot read the Android phone. iTunes goes with Apple, its the basis of a smartphone to have a software where you could easily transfer movies, music etc to it.
Am I missing something here?
Yes, you are missing Android File Transfer, which is available at Android.com
www.android.com/File Transfer
Just download that, install it, and Robert's your mother's brother.
How can i heal back my lodspeaker? I was on skype used my loudspeaker then when i ran out of juice i put the phone on charger, went back to skype no voice at all on the loudspeakrr. I tried restart factory reset. Tried*#0#* service code no voice came out. But wgen i pluged in and out my earpice . Time to time it makes some noise for 1seccond . Thats it i hope u can give me some advice thanks. U are awsome
This is one of the app to sd apps I have, as you can see I have numerous apps I am able to send there
This shows the card is installed and the phone can see it
But this is all I see when I try to send stuff to the card, I have tried renaming the card but my pc won't read cards for some reason and my laptop is being repaired, if it's going to work I can use a friends to do it, I know what you said above but does that basically mean no matter what I call it the phone will still see it as an sd card? Can I rename the internal sd memory to make it work?
hey
so i wanted to copy a video to my pc, i got the cable and connected the phone, then afterwards i did a factory reset.. ever since there has been a folder in the gallery with the computer's name, nothing inside it "it won't open" if selected nothing else ca be pressed, even the delete button doesn't appear :/
i tried formatting the gallery "through the pc, and through the antivirus" but its still there! everything else got deleted except for that folder :/
please help!
thank you but it didn't work! and i downloaded the app "es explorer" it couldnt find the folder, it's like something that can't be dealt with
Has anyone on Verizon noticed a sudden increase in battery drain relative to Cell Standby? I could swear it was in the single digits before, but now I'm seeing Cell Standby around 32% of battery drain by the end of the day. This has been happening for about 3-4 days now on my S3 as well as the wife's S3. I can barely get through the day on a full charge whereas before the battery was regularly in the low 40%, high 30% range by the end of the day.
I did the basics, checked phone app settings, checked for rogue apps, battery pull (several times), checked that I didn't enable/install anything that'll kill the battery, etc. The kicker is that it suddenly started on both our phones a few days ago. The only thing we did differently earlier this week that I think would impact this is we used wi-fi direct for the first time to transfer files, but I checked repeatedly to be sure that service is off on both phones. Any ideas?
This is a known issue across all S3 variants. There is a sticky thread with a petition to get Samsung to fix the issue.
Thanks, jerofld. I did see information on the web that it was a known issue, and my bad for not mentioning it. However, I guess what I'm asking is why did this suddenly start happening after 3 weeks? And it started suddenly on both mine and my wife's S3 out of nowhere. My understanding on the issue is if your phone has it, then it has it. My Cell Standby was otherwise less than 10% of battery drain previously, and suddenly the last 3 or 4 days it's at 32%, same as the wife's S3.
I'll read more on the sticky, though, maybe I don't understand yet the depth of the issue.
Do you root? I'm under the impression that everyone has it on all variants. I just thought it was a recollection thing, where it just seemed like it was higher than normal today.
Unless you root and had the cell standby recalculation fix installed and switched to a ROM that didn't.
No, haven't rooted due to the locked bootloader, but I hear Verizon is going to release a fix that will unlock it. But even then I probably won't bother with it as this is the first Android device I've had that I'm actually very happy and impressed with the stock performance. That is, unless this Cell Standby thing doesn't get fixed and drive me to the point that I root.
 I love Titanium Backup and LBE Privacy Guard too much to not root.
  I love Titanium Backup and LBE Privacy Guard too much to not root.I don't know what to tell you, then. Everyone I know of that has a GS3 has this issue (except those who root and install the fix). Honestly, the phone has been good with battery with me that I rarely even check the battery page. I get 16 hours of moderate use. I rarely have to plug it in to recharge during the day. So the problem hasn't really bothered me all that much.
And there's more reasons to root than just performance tweaksI love Titanium Backup and LBE Privacy Guard too much to not root.
And that's where I'm coming from. The first 3 weeks with the phone after 15+ hours I was almost always above 40%, sometimes in high 30s. It was never an issue until the last few days, that's why it seems odd to me that out of nowhere the last 3 or 4 days the drain started happening.
That's I posted summarizing what I read on the XDA site. I know the issue effects all varient's but I did not believe it effect all phones. I thought you either had the issue off that bat or you didn't. I did not realize it was something could magically just appear. Thanks for the info guys
Kies can sync multiple items to the phone, like media files and pictures. It's the official Samsung app and can be found here: Transfer, Sync & Manage Music, Movies, Photos, Contacts and Calendars with Kies
If that doesn't work for you, as that's the US version of Kies (and I can't get google to give me the international link, should you be outside of the US).
Personally, I prefer AirDroid as it doesn't require any residual software on the machine and will work via any web browser.
I think your speaker is broken. If you can return the phone, I would recommend you try that. Does the speaker make any sounds, like if you play music?
Just because an App2SD app says it can be moved doesn't mean the phone will allow it. Android has an App2SD mode built into it (and has since 2.2 Froyo), however, the configuration of the Galaxy S3 doesn't allow for this to work. Apps2SD was for phones that relied on SD cards for storage. Google/Manufacturers are trying to get away from relying on SD cards.
