Samsung Galaxy S4 Mini Screen Replacement Guide
repairsuniverse
This repair guide will show you how to take apart the Samsung Galaxy S4 Mini, Which will help you perform a basic repair and help you with any problem you may come across such as a cracked or shattered touch screen digitizer, a damaged LCD screen, or other faulty internal parts such as buttons, speakers, and torn flex cables. So please use this repair guide to help you in the disassembly of your Galaxy S4 Mini and to help you replace parts and get your device looking and working like new again!
This guide will help with the installation of the following Samsung Galaxy S4 Mini parts:
  • Samsung Galaxy S4 Mini LCD + Touch Screen Assembly - Blue
  • Samsung Galaxy S4 Mini LCD + Touch Screen Assembly - White
  • Other Samsung Galaxy S4 Mini parts
Required Tools:
  • Small Phillips Screwdriver
  • Safe Open Pry Tool
Samsung Galaxy S4 Mini Repair Guide:
  • When starting this repair be sure that your device is completely powered off.
  • Now begin by removing the back battery cover. Note, to remove the cover it
