Help Samsung galaxy tab 2 7.0 Wi-Fi won't turn on
From what I can find, the WiFi antenna and connector is part of the button assembly. If you read the repair guide sticky it's the upper left hand connector with the power button and volume up and down buttons.
The button's are attached to the back plastic assembly, but, the switches are glued to a copper strip and it's pretty fun getting it off. It also seems to be a part of the infrared blaster at the bottom.
https://www.gounlock.com/details.php?itemId=8205
Samsung Galaxy Tab 2 P3113 Side Button Key Power Volume Connector Flex Cable | eBay
There seem to be slight variations based upon if you have P3100, or P3113, etc.
