riggirubio
pls help! my samsung galaxy y back button stopped working. what should i do? i reset my fone but it didnt work. i even restore factory settings still it didnt work. pls help me
Worked in my case, I changed the screen guard and it went fine.maybe your screen protector is too thick causing the screen to response hardly , use a thin one .
Once your phone is turned on, you will1. Place SoftButtons.zip in your sd
card.
2. Enter recovery mode (cwm)
3. Mount system
4. Select apply zip from sd card
5. Select SoftButtons.zip
6. Installation will begin.
7. Once done, reboot your system.
Download HERE
