It appears that you need to go into the Application Manager and clear cache on your most used apps and widgets.
Also, make sure you have no media (songs, ring tones, music, pictures, etc) in the internal storage that can be moved to the external sd card, freeing memory. Some device operating systems are meant to store some media in the internal memory and other on the removable sd card. Check to see what you can move out of internal memory.
Be sure to restart your device after making any changes.
