Root Samsung i897 Captivate 4.4.4 Kitkat Rom
Manoj210891
Features:
CM11 based on the latest Android 4.4.4 Kitkat.
Rewritten Brush Script to support lower version Recovery Brush.
join Xposed framework while adding (GravityBox) gravity toolbox.
call to join native attribution display; input method using the latest flight information voice input method; default join fast map browsing and RE Manager and browse faster; default installation of the software can be uninstalled if that is not practical; right All apk were Z ipa lign aligned optimization; against some of the features introduced in the ROM, please read the following "Brush notes." / * Brush Notes * / 1, after reducing the demand does not mean that all Recovery Recovery can brush, brush better for a key support for the effect, if not the brush into Check Recovery version, as far as possible be based on CWM Recovery Brush version! 2, open the USB debugging features, please enter [Settings] in the [on the phone], continuous click [version number] will open after 7 times [developers] option to enter developer mode can be turned on USB debugging [] and [Senior restart] menu functions. 3, CM of the system performance to play well, you can go to [Settings] in the [performance], the adjustment of the processor's frequency, rationally adjust the processor frequency and CPU regulator can achieve energy saving effect and increase speed. 4, due to the different needs of everyone, we did not join the Google service by default, so you are free to download if necessary into the brush into the download page] [GMS -(Google Mobile Service)
