I just bought a Samsung Galaxy Indulge for 20 of a friend but it has no sim card on it ? Where and how could i get one so i can connect it ASAP !
Yes indeed it is a Metro indulge and will do , And a cooperate store would be a Metro Store?
they (metro store) told me if you take those things out it will brick your phone, so of course i never tried it.
Hi, question.... what does "BRICK" and "ROOTED" mean? I have an indulge but it's damaged so I was planning to buy a indulge without a SIMCARD, i have a simcard from my phone to put on that phone without a simcard,would it work or would i have problems? please help me I don't understand what any of this means...![]()
it might have to be registered to ur esn number like regular metrophone, i doubt it will harm your phone. the worse that i can see happening it saying network error.It would appear I was wrong. The new UICC card they brought must have been for another customer in the store. Because I just looked at my UICC card, and it's quite used...
The only thing is I am still not sure if they are transferable.
I'm thinking of swapping my with the one in my gf's phone and see what goes, I just don't know what to tell her if it fries both phones yet, so of course I'm sonewhat hesitant...
I'll do a test and if I can place calls while the uicc card is out of the phone, I'll consider the swap. I just wanna make sure I'll still have a phone if I need to replace the uicc card...
Also, it is my understanding that the uicc cards are phone specific, and are programmed for your device alone.
Remember, they do not cover cdma service per se, so you will still have to reprogram your new indulge, even if by some stroke of luck the UICC cards were transferable.
