Swiftkey had something on their website about there being an issue with Samsung phones that reset the default keyboard from keyboards purchased in the market to the samsung keyboard on reboots. This is because of permissions issues I believe. Is that what you're having problems with?
Or is it resetting the default keyboard even without rebooting?
So you have to either freeze the stock keyboard or move the downloaded one to system so the only solution is rooting? How about Tasker, could that be used to change keyboard as soon as the phone boots?
I dont remember having this problem with ICS![]()
I read on a different forum that the 4.3 update being pushed to AT&T S3's fixes this problem. Being as my HTC that was running 4.1.2 didn't have this problem and after hearing about the issue being fixed I'm going to blame Samsung.
I don't understand the fuss: I am not rooted and have been using Swiftkey since I got this phone w/o any problems. Tried Google but preferred Swiftkey.
JM
The problem I and many others were having was that if you rebooted the phone it defaulted back to the Samsung keyboard. I didn't have the patience to keep switching it back so I just stopped using swiftkey. After the 4.3 update I have started using it again.
I had this exact problem since updating to 4.1 I believe and the upgrade to 4.3 fixed it...yeehah.
Luckily have only had one minor issue with 4.3 so far (knocking on wood) but on the flip side exactly what is the benefit? I am having a hard time recognizing any!
