Samsung Kies 1.5.3.10093_82 D/L Link
troyr
I created a torrent on Demonoid if your d/l speeds are killing ya on the other options. If you don't have an account you have 2 weeks from today to find it. I believe that is the non-user limit. If you need an invite, PM me and ask nicely and I may provide one.​
Samsung Kies 1.5.3.10093**_82 - Demonoid
Any random Q's @TroyR
did you have to do anything special? because i cant get kies to make the connection to my captivate.
I made sure TouchWiz was set as default and that kies was set under USB settings, then I just connected it to Kies and it worked.
Android Forums is a place where we all work and help each other collectively. Keep the rude comments to a minimum...and by minimum I mean 0 ;)
How do you set touchwiz as default because I'm using Launcherpro right now.
I use launcher pro as well. I don't have to set touchwiz as default just launch it. FYI you might not have to set it as default either...just will save you a small bit of time.
I downloaded the new version, but when it tries to connect to my phone it still gives me the message "The device is not supported by Kies". I am not running any other launcher but Touchwiz, though I am running the leaked Froyo, could that be the reason it's not accepting it?
Same boat as you socalrailroader....I have Cog 2.2 beta 2. I think when I flash back to stock it will recognize it.
That is the reason, you are correct.
i cant even get kies to run on my computer, much less get to the point of recognizing the phone. i've mentioned my problem in several threads and never had a reply. guess i should try on XBD(sp?) forum. seems more of a coding thing clashing with something on my comp
