C Cavac Lurker Nov 2, 2013 #1 Whenever i use and charge my phone at the same time, my battery decreases instead of increasing. Is this normal? And if it is not, how do i fix it?
DragonSlayer95 Resident Air Bender Nov 2, 2013 #2 Are you using the stock Samsung charger that came with it? As well is it plugged into the wall or computer via USB?
DragonSlayer95 Resident Air Bender Nov 2, 2013 #6 So it's plugged into the wall then yeah? If so, you might have a charger that's going bad.
DragonSlayer95 Resident Air Bender Nov 3, 2013 #9 Have you tried using a different battery? It could just be your battery as well.
