Samsung Mobile S4
halling51
Hello.
Thanks so much for reply.
Nothing is working after several reboot , updates, win reboot etc.
regards and thanks in advance
Halling51
My Wife's Phone had/has this same issue (We are on Sprint). The last time it happened we ended up going in to Sprint and it turned out while we were out of town, Sprint updated their towers in the area and pushed an update out to all Samsung phones that were affected. Because we were out of town she did not get the update.
They were able to fix this by entering some codes in the store and we were out the door in 5 minutes. The rep we talked with said it was something specific to Samsung phones.
NOW since the latest update she downloaded, she is not able to connect again. I plan on calling Sprint tonight to see if this is an easy fix again and if it can be done over the phone or if I need to stop in.
I will report back what I find out.
Hi everyone
Thanks for all to suggestions one my problem.
I have this solved out by adding the app AirDroid to the phone. It works perfect together with my computer and all is ok.
Thanks from NORWAY!
