Root samsung moment stuck on samsung screen?
I rooted my phone and tried to switch kernels and when i did my phone is just stuck on the samsung screen. I even tried to reflash using the sprint update but nothing is working. Ant ideas? PLEASE help
Do you have a custom recovery installed? I have 3.0.8 and there is a factory reset option, i would give that a shot or if have any system backups to possibly restore.
Hey the problem you may have ran into depending on if you have a custom recovery.
I used SPRecovery, but if you can try and to clear cache and clear history phone data.
I forgot what the 2 options are but you must clear those before loading a custom rom with root. Otherwise your phone will never load. try that and report back. just to double check.
I did that and I had the samsung screen where it would just restart at the same screen
How long did you wait? Sometimes it can take awhile. I switched roms last night and it took my phone about 5 minutes to reboot. I thought it was stuck on the Samsung screen as well.
Well from what I've noticed youll see the samsung screen refresh if it does it a couple times then it will be stuck. Theres a difference when it works and when it freezes
Did anyone ever figure out a fix for this? My phone will boot up to the Samsung screen, then will not go any further. I am using noobnl-Radioactive-FroYo-romv1.8.7 rom and it was working fine, til i was tether wirelessly earlier. My phone froze, so i restarted it, now it will not boot past the samsung screen. I cleared the cache, and even tried rebooting to factory reset.
When i try to apply the rom from zip, it says
E:cant format system
E:failure at line 2:
format system:
Any ideas?
