Help samsung moment sync trouble
i cant get my moment to sync right with my pc. im running windows 7. when i plug the device up to the pc, it reads that a device is connected but i cannot open it (just says please insert drive). and ideas what might fix this
Go to Settings > Applications > Development. Uncheck USB Debugging. See if the PC recognizes your SD card after you do that.
I havent mounted my phone on a win7 machine but on xp sometimes i have to unmount my sdcard (menu>settings>sd card & phone storage>unmount sd card) and then reboot the phone to get the notification in the phone to mount to usb. Another thing to do would be download usbdeview (View any installed/connected USB device on your system) and uninstall any drivers related to samsung or android and reinstall the latest driver package included with the 2.1 swupdate. Lastly there is a thread over at SDX about wireless ftp connection to the sdcard bypassing the usb completely, this does however require a wifi connection to your network. This is the link to that thread
[HOW-TO] Wireless Access to Your SD Card
