Help samsung note 2 volume(headset) problem solved
Step 1~ Open: "settings"
Step 2~ Click: "sounds"
Step 3~ Click: "volume"
Step 4~ ...from that point, you would see 4 options (volume, media, etc/ringtone/notifications/ and system)...Click the ringtone option and slightly readjust the tpne until the volume tone options relight...
Step 5~ you can now readjust the volume/media tone to your preference...
-NOTE-
......if you drag the "ringtone" option back to silent, IT will mute your sounds again....
Pretty much it to it...just play with it till you figure it out for yourself. ..
