louisburgueno
Greetings, my Samsung Note 3, stock 4.3 audio volume levels will change
Is the hearing damage popup something we can disable? Do you know where it might be? I frequently have my phone connected to a stereo (at home, in the car, at work, etc) and control the volume via a Pebble watch, and that hearing damage popup breaks remote volume control.
iwoloschin, the popup always pops but I use a Tasker profile after the popup to set the volume back to max. I don't know if that type of set up will fix your pebble.
