Help Samsung Note 3 unknown icon
ldglover
I have an unknown icon in my notification bar. A little black window with white horizontal lines. I have turned off all notifications, stopped programs from loading at startup and searched though all programs for similar icon with no luck. Help if you can please.
Peace,
LD
Peace,
LD
Do you have a task written in an app?
Finally found it! Program I use for Data management called "My Data Manager". I have used this for a while, but the Icon only showed up when I got my new Note 3 and re-installed everything. Unchecked the status option and its gone! Thanks....
