Upgraded to ICS, no issues. But--since then my battery is being drained. I believe it's because of a program called Samsung Push Service. I've seen some references to it that say it sends notices of updates for the Samsung App program. It can be uninstalled, but as soon as you click on the Samsung Apps, it apparently reinstalls itself.
Has anyone else come across this? Found anyway to permanently disable? Know if uninstalling it has any undesirable effects on the Samsung apps themselves? Thanks for any feedback.
Running stock with no intentions of rooting or going for custom ROMS. Looking for others with same setup for feedback. Thank you.
Elly44
Elly44
