Help Samsung Reverb SD Card Help.
You can either go to the My Files app and move the files you want or you could connect your phone to your computer and move your files that way.
You can't yet install apps on your SD card, but you can put your books, movies, music, etc. on there.
Easiest way is to hook your Reverb to a PC using a USB cable. You can then see both the Reverb's internal memory and the SD card.
Open a Windows Explorer window and look under "Computer" for a device named "SPH-M950". Under it you will see two entries named "Card" and "Phone". The "Card" is your SD Card. You can put your stuff in there.
I have a reverb that is out of space and a 16 gig sd card I can't use. Just going to my files does not lead one to the answer of moving books, music, etc. to the sd card. I run linux so I can't just pop in an usb cable and do it that way. Could someone please post an answer to this very frustrating problem with a little more detail??? Thank in advance.:mad:
Open the My Files app: Under /mnt you should see two cards:
sdcard (the internal one)
and
extSdCard (youur new card)
Navigate into sdcard, and long press on a file or directory until you get a menu. From the menu, choose "move"
Now, navigate to your extSdCard, when you get to the spot where you want to install the file, choose "move here" from the top bar.
