I listen to alot of music on samsung, i download torrents onto an external sd card and play it off the music player.
But now the music player has a deleted half of the files from the library , eg i had 6 albums by brmc and they all played through smoothly,
now whenil i go in theres only two albums and one doesnt even.play (It says music player cannot support audio format)
The files have not been deleted because i go into my foles onto my sd card all the files are there and will play when i click into them.
Id really like if someone could help me fix this because i cant find a solution anywhere.
Ask any questions you like if you need ro.
Thanks, Sam
Thanks, Sam
