Help Samsung Tab 2 7" - Android apps download problem
csk1411
Hi,
I have Samsung Tab 2 7", facing error while downloading any application from Play store e.g. error code 495 and while updating apps it throws error code 927 and due to this no download completes.
does anyone has solution to this problem.. please revert asap.
You can try clearing the cache and data from the play store app and try to download the app again.
Btw- Welcome to the forums csk!
Even i have the same problem. Google apple store is not working. Just keeps on coming .. downloading. But it never completes.
Did you find any solution for the problem. Even i have the same problem and tried searching on Google support. And device .GT-P3100 is not in on Google play store supported list.
For those having a problem, did any of you at least do this? Clearing cache and data is your friend.
I cleared the data cache several time sin several combinations. Some other threads also referred to clearing the download data cache, but I could not find one of them in the settings of my tablet--I assuem that ICS has a different structure. No luck with any permutation that I tried.
My red x always come on when charging my battery, and when I disconnects it and charge it back, it dissappears and when I remove it and charge it again, it comes up whats wrong pls
