Root Samsung Universal Gingerbread Root & Unroot 2.3.3 -> 2.3.7+
Did you root your phone successfully with this method?
  • Total voters
    8
StoneBoyTony
UNIVERSAL GINGERBREADROOT SAMSUNG GALAXY MODELS: GT-S5570, GT-S5570B, GT-S5570I, GT-S5570L, GT-S5571, GT-S5578 (Chinese-Mini), GT-S5660, GT-S5660M, GT-S5660L, GT-S5660V, SHW-M290K (Korean-Gio), GT-S5670, GT-S5670B, GT-S5670L, GT-S5830, GT-S5830B, GT-S5830C, GT-S5830D, GT-S5830F(La Fleur), GT-S5830G, GT-S5830i, GT-S5830L, GT-S5820, GT-S5830M, GT-S5830T, GT-S5830V, GT-S5830Z, GT-S5838(Chinese-Ace), GT-S5839i, GT-S6800(Africa-Ace Advance), GT-S6802, GT-S6802B, GT-S6802L (new), GT-B5330, GT-B7510, GT-B7510B, GT-B7510L, GT-B7800, GT-B5510, GT-B5510B, GT-B5510L, GT-B5512, GT-B5512B, GT-S6102, GT-S6102B, GT-S5300, GT-S5300B, GT-S5300L (new), GT-S5302, GT-S5302B (new), GT-S5302L (new), GT-S5360, GT-S5360B, GT-S5360L, GT-S5360T, GT-S5363, GT-S5367 (new), GT-S5368 (new), GT-S5369, GT-S5690, GT-S5690i, GT-S5690L, GT-S5690M, GT-S5690R, GT-I8150, GT-I8150B, GT-I5510, GT-I5510B, GT-I5510L, GT-I5510M, GT-I5510T, SCH-i110 (new), SCH-i509, SCH-i559, SCH-i589(Ace Duos -Chinese/India), SGH-T499, SGH-T499Y, SGH-T499V, SGH-T499W, SGH-T589, SGH-T589R, SGH-T589W, SGH-I837, SGH-I857.
The thread expand in a very big size and can't be posted here but I made a PDF file so you can download it from here or you can visit me on the next link.
NEW UPDATE ON: stoneboytony.blogspot.com
√ Do not add mirror in my releases!
√ Support the developers!
Download The Leatest Tutorial:
Universal Gingerbread Root & Unroot 2.3.3 -> 2.3.7+.pdf
Regards
StoneBoyTony
im using 2.3.6 with the baseband version of s5570XWKT2 and buildnumber of JVKT1?is that compatible..sorry for noob question
busybox are missing after i root my phone...do i need to install it manually..and can u pls give me give me the apk for busybox..thanks
Busybox is binary is not a program apk...the apk program just will confirm witch binary version you have on your phone. Busybox is additional handy LINUX / UNIX based commands that runs thru ADB Shell and some programs are depending from this binary so they can functioning properly. And it doesn't matter witch baseband version of phone you have, as long is Gingerbread you don't have to worry about.
Programs that are worth to have root on your phone. Example:
- TitaniumBackupPro
- ROM Manager
- Market Unlocker Pro
- SD Speed Increase Premium
- Root Explorer
- System Tuner Pro
- SD maid Pro
- Root Call Blocker
- Voltage Control Extreme
- ROM Toolbox
- Tasker
- Wirless Thether for Root Users
- Terminal Emulator
- Droiwall - Android Firewall
- Button Savior
- Virtual Button Bar
- Set CPU for root users
- Boot Manager Pro (not for samsung Galaxy mini)
- Sixaxis Controller
- Hexamob Recovery Pro
- LBE Privacy Guard
- TitaniumBackupPro
- ROM Manager
- Root Explorer
- System Tuner Pro
- SD maid Pro
- Root Call Blocker
- ROM Toolbox
- Tasker
- Terminal Emulator
- Button Savior
- Boot Manager Pro
- LBE Privacy Guard
bro..how do you use voltage control extreme?+karma for you..can i use this all apps if im on stock rom rooted?can you pls show me some tutorial for galaxy mini in this apps.Set CPU for root users,Voltage Control Extreme Boot Manager Pro..thank you so much..first time to root my phones...im a newbie..i want to learn something..
examiner i really don't have the time to explain everything this is a new chapter for you i know and you are so exited is not something you can learn in one day is not the place and time here. You can google search here or XDA forums or any other forum for that answer. My point was to show you the way the rest is yours. And yes they are all working on stock rom.
after i rooted my phone...it becomes laggy and restart itself...so i have to unroot my phone....no luck for me this time for rooting...any idea?
When I upgrade my Samsung Galaxy Mini from froyo to Gingerbread I have never have any problems with the rooting or any kind of restarting couse I only use Stock Rom never custom so in that case I never ever really used ROM Maneger couse I know it is bricking the phone 50/50 chance by putting CyanogenMod . I was on S5570XWKQG Gingerbread UK 2.3.4 rooted the same file as it is now and no problems then I upgraded after 1 month to S5570XWKT7 Gingerbread CRG 2.3.6 and again rooted with the same package and no problems. You must be doing something wrong with some application or your firmware is custom and something is not compatible or is some unique rom that is only available from your mobile provider. Beside that I can't help you the rest is what you have done.
When I upgrade my Samsung Galaxy Mini from froyo to Gingerbread I have never have any problems with the rooting or any kind of restarting couse I only use Stock Rom never custom so in that case I never ever really used ROM Maneger couse I know it is bricking the phone 50/50 chance by putting CyanogenMod . I was on S5570XWKQG Gingerbread UK 2.3.4 rooted the same file as it is now and no problems then I upgraded after 1 month to S5570XWKT7 Gingerbread CRG 2.3.6 and again rooted with the same package and problems. You must be doing something wrong with some application or your firmware is custom and something is not compatible or is some unique rom that is only available from your mobile provider. Beside that I can't help you the rest is what you have done.
whats the new features in this CRG 2.3.6..i only use stock rom..sine i begin to use android phone....when the restart happens and the memory card scanning..i only use the sd speed increase and the keyboard manager and of course the droidwall..thats the only application i use after rooting my device..and when i unroot...back to normal again..i only use application that are compatible with my phone..my apps is only medical apps,some for editing like officesuit,quickoffice,roadsync and some gallery apps and DR web...
Well in S5570XWKT7 Gingerbread CRG 2.3.6 There are alot of improvments firs thing is that i have noticed is in the fast reaction of the touch screen, battery is now more stable it doesn't drain like v2.3.5 stable wifi, GPS, applications running smothly is best version untill now. From Froyo to Gingerbread 2.3.6 is like jumping from Suzuki Swift to Mercedes ;)
And another thing about Unrooting. When you unroot with the zip file always must press on"wipe cache patition", "wipe data/factory reset... select Yes--delete all user--" and the best thing is before you reboot remove the SD card and press reboot now see if it makes any diference.
ok thanks..can you show me some screen shots where to put the files in odin after i unzip the file...i umzip it and its a tar file...one package
REMEBER THIS IS FOR EUROPEAN CARRIERS PHONES ONLY
1. First thing unroot the phone like I told you in the Previous post
2. Remove SIM Card and SD card and put your phone in download mode (remeber battery must be charged at least 70%)
3. Follow the picture it will explain all and it does not matter where you will put the S5570XWKT7_S5570XWKT3_S5570CRGKT1_HOME.tar.md5 on your hard drive is about when you browse with Odin to find it where did you put it.
4. Fallow the steps from the picture and all is done
do you have any means or ways were i can increase the internal storage or move the apps to sd card?..whats the use of busybox application?..and how can i change the samsung animation in start up...
Hey, i have a problem rooting my Gingerbread 2.3.5, when i update from the SD card i get this:
E: Error in /tmp/sideload package.zip
(Status 7)
Installation aborted.
What am i doing wrong?
Thanks
(Status 7)
Thanks
1. Enable Unknown sources
2. The zip file put it in already created folder on your SD card "Applications"
3. Execute the zip file from that folder
4. You must have Stock Rom to get this work with the rooting
Thanks for the quick answer, i have already tried the first 3 steps, with the 4th i have one question, where do i get the Stock Rom? Isn't it dangerous for the phone?
Stock ROM is as you buy it from the mobile provider. Other Stock ROM can be found here: http://droidangel.blogspot.com/2011/05/samsung-galaxy-mini-s5570-original.html Tell me are you using the default 2GB SD card? If you are using more than 2GB can be a problem so try tu put the 2GB SD card and rename the file to update.zip and see if it will work. ;)
I have the original ROM and the original 2GB SD.
Still does not work.
Anything else?
Try the new update zip now plenty models included ;)
whats this new firmware from poland...it has a new lockscreen..its XWKTH s5570 2.3.6..its csc is XEO=Polish open...
I have no idea I'm fine with the Croatian version 2.3.6 I don't need anything else now or in the near future since is the most stable version for me.
My network: 3
Country: uk
PDA: S5570XWKQG
PHONE: S5570NEKQ3
CSC:S5570H3GKQ4
Kernel version
2.6.35.7-perf - CL561937
root@DELL145#1
Build number
GINGERBREAD.XWKQG
Hi
I have run the universal unlocker on my galaxy mini with the above details. It ran as the instructins sid it would and I got an icon for SU on my phone. I want to change from the
My network: 3
Country: uk
PDA: S5570XWKQG
PHONE: S5570NEKQ3
CSC:S5570H3GKQ4
Kernel version
root@DELL145#1
Build number
GINGERBREAD.XWKQG
Hi
