I bought a Samsung Fascinate a few days ago, and have been trying to resolve an issue with the USB transfer.
First of all, I have the correct drivers installed on my computer because I connected my wife's Samsung Fascinate to it and it brings up the USB icon on the phone to select the mode. However, on my phone, nothing comes up at all, and Windows 7 says that the USB device has malfunctioned.
So, I did a hard reset on the phone, and this did not fix the problem. I also performed a factory data reset, and this did not work either.
Now the phone charges just fine, it's just that the USB data transfer does not work. I also checked to ensure that the USB mode was set to Mass Storage, and still nothing. I even tried doing Media Sync to see if it would at least pick up the phone, and it does not. I also tried changing USB cables, and no luck there.
So, I took my phone into the Verizon store. At first they thought I hadn't setup the phone for Mass Storage, so I made them plug it up to a computer there at their store, and they could not figure it out. I asked them if they could somehow reflash the phone, and they said they would not be able to.
So I am running out of options here. The rest of the phone works just fine. I can make phone calls, use the web, and do everything else, except for use USB data on it. I thought if there was a way I could copy an update.zip to the phone somehow and go into the bootloader and run the update.zip if it might re-install the firmware. Does anyone have any suggestions at all?
Also, I cannot download the new Samsung OTA update either, it keeps saying it's not available. I thought if I could download this it might fix the problem.
