Samsung vehicle mount?
I don't own it but can comment on the size. The Note is a 5.3" screen, which is also a little wider than the Note 2. Although the Note 2 has a larger screen at 5.5", its body is a little narrower than the original Note.
Edit: there's a reviewer who stated a Note 2 in a Otterbox Defender case fits in it with no issues.
I bought it for my Galaxy S2 and the Note 2 fits in ok with my Samsung protective case fitted to my phone.
1.) Anyone know if this vehicle mount will work with the Note2? Samsung Galaxy Universal Vehicle Navigation Mount it is listed as an accessory for the Note2, though it doesn't specify that it works with it? It only indicates that it will work with devices up to
5.3 inches.
2.) Anyone who has used it recommend it?
Thanks.
About everything there is to discuss on this topic can be found on this thread unless something has changed in the past few weeks. A lot of us are seeking the perfect solution for a car dock and have yet to find it.
http://androidforums.com/samsung-galaxy-note-2/626973-official-vehicle-dock.html
