Hey,
I unlocked my Samsung Galaxy S Vibrant to work with T-Mobile. However, I haven't received the OTA update for the vibrant (presumably because I am using it with AT&T). Also, I mainly have access to a Mac so I can't download Kies.
What is the easiest way for me to update the Vibrant so that the GPS fix and other bug fixes can be applied?
Thanks in advance
Edit: Also, would the update force me to unlock again?
Well, you really need a Windows machine for this one. You'd have to install Odin or Kies Mini and flash the update (I presume you are referring to the JI6 update) through that. I don't know of any stock JI6 ROM that can be flashed via ClockworkMod.
You could always install a custom ROM with Clockwork and avoid Odin or Kies Mini, but if something goes awry you'll have to use Odin to get back to a working OS.
And yes, you won't get updates because you're on AT&T.
Go here for more information on the things you'll need:
[REF]***Vibrant Directory(Bible)Rev2.2--Time: the 4th dimension--***(11/22/2010)*** - xda-developers
Hey wait...I came across this...maybe you would be able to use it?
Samsung Wave - Support - Samsung Mobile UK
It appears as though you can download a Mac version of Kies Mini there. I have no more information than that however. Click on Software and you should see the link for Kies Mini.
