Sadly mine has been a lot weaker then my S3 or Iphone 4s. Used to get 3-4 bars easily and now getting 2-3 at work. Still wouldn't trade my N2 though.![]()
"Number of bars" is arbitrary, and relative to a given phone, in regards to actual signal strength in dBm readings. I got "3 bars" with my at&t Note 1, when dBm was at -97 to -103...however calls start to fail, and data fails to connect at these levels. I think 3 out of 5 bars is a bit overstated in this case.
What's everyone's opinions on there radios? I came from the charge and a s2 shortly... My note comes in everywhere my charge didn't after a few days of use...I hear lotsa talk about how they suck...they must not have a note cause they have improved alot in my opinion...
Got this off another forum. Would this be correct?
dBm Signal Strength
-105 to -100 = Really bad
-99 to -90 = Not great
-89 to -80 = Pretty good
-79 to -65 = Good
Over -65 = Excellent
dBm Signal Strength
-79 to -65 = Good
That seems according to old RSSI signal measurement standard. That doesn't apply to LTE phones with Android 4.x, OS. But it was correct for 3G android phones with OS up to 2.3.X.
Simply put, subtract about 15dbm to above numbers for RSRP signal reporting on LTE phones. -120dbm is about where LTE signal starts dropping, which is in line with my experience.
This post on rootzwiki explains that well though it's a bit length. But it's worth of reading to understand how signal is reported on phone.
[APP][2012-12-20] Advanced Signal Status v1.1.3 - Android Applications - RootzWiki
Lucky you. .."my" LTE Note fails to load web pages at -105dBm, or "2 bars". Even loading these forums via Tapatalk.
