Sandisk Ultra MicroSDHC
elfy23
Member
Have any of you guys experienced problems with a Sandisk Ultra MicroSDHC? I recently bought one and when inserted it starts scanning but keeps getting "Unexpected Removal" problems. I reformated the card using minitool to Fat32 but it still doesn't work. Any suggestions? Maybe the card just isn't compatible with our phone?
I had the same problem..but with a 32gb one. I just bought a different sd card after reformats time after time.
Wow, nope wouldnt know about that one
I thats the same as miine i have 32gig. One in each of motions. They work fine
Pretty fast to
Yep both are fat 32
Does. Your conputer let you add fikes and stuff?
Have you rebooted with the card in the phone?
Yep both are fat 32
Yeah. I was able to add music and my pictures. When i reboot my phone it goes through the scanning process and, at times, it finishes but then the "unexpected removal" pops up. Might try again.
Do you think the card itself has a flaw?
Can you go to the store and ask to test another
My two cards worked great with not a hitch.
Though i dont understand why computer reads and writes ok
Yeah, that's the weird thing. My sister and brother in law have androids, the motion and admire. I'll test it in there's
Alright so my sisters admire 4g read it. No problems but my brother in laws motion 4g got the same problem as mine.
