Help Save Issues on Final Fantasy 7 on Psx4droid
Cloud1989
Final Fantasy 7 runs perfect on my Droid incredible but when i go to save in game it shows that i saved my game but when i try to load my save file its not there. Has the happend to anyone else? Has anyone been able to fix this problem?
The first thing I can think of is that the game or emulator is saving the file in a location that it shouldn't. So it shows that it's saved because it created a file, but when you go to load the saves, they're not where they should be. My best guess is to dig around in your app folder and see if you can find the save games, and then try putting them in other likely locations. That's very imprecise, but it's about all I can think of. Maybe others have had this problem and know the solution already, though. Good luck.
Thanks ill try that. I just tried again and saved. It showed that I saved. Than I hit reset and tried to load and my file was there. Than I went back to the main menu and hit menu on my phone than hit close. It close out and went back to my bin file. Then I reload ff7 and try to continue but my file is missing. Im going to trt again but this time exit a different way. Let me know what you think
