Help Saved attachments to SD Card...viewing them?
BigHAZE
I saved some email attachments to the SD card when asked...but how can I view them? Clicking the paper clip asks me if I want to save it again. I know I can probably connect via USB to view on the PC, but is there an SD card "viewer" that I cannot seem to locate?
Thanks
They should be in \sdcard\downloads
You can use File Manager from the market to view them on the phone. If you see them then you should see them on the computer too.
Is there a way to do it without a downloaded app?
Sent from my HTC EVO 4G
Gallery will show pictures, QuickOffice will show documents, Music will find mp3's. I'm not sure about video files.
File Manager is just an easier all-in-one app to look at the files.
