3 325i Well-Known Member Sep 24, 2010 #1 Where are the custom saved scenes saved? I want to delete a few that i saved a while ago. thanks
3 325i Well-Known Member Sep 24, 2010 #2 sorted, Setttings > Personalize > Scenes > Select the scene you wish to delete then press Menu then Delete.
snowmobile Android Enthusiast Sep 24, 2010 #3 Menu / settings / personalize / scenes then press menu again to get the option to delete the ones you no longer need. Oh it's sorted!
