Help Saving a text picture?
Annmarie
My husband got a new Samsung Continuum. I have a Droid X, and have no problem taking a picture that was texted to me and saving it and making it my wallpaper. I absolutely can not do this with the Continuum. I found something on line that says to pause the picture and there will be options to choose from. This does not happen. Any help? Thanks.
From the MMS message (text + picture):
While viewing the message,
touch the MENU option,
touch ATTACHED ITEMS,
select photo and touch SAVE.
To save as wallpaper, you'll need to go to your photo Gallery and then manually select the folder 'download' (should be the top photo), then select the saved photo, touch 'Menu' , 'More', 'Set As', and then pick 'Wallpaper (or 'Contact icon' if you prefer)
That should work. Hope that helps.
