Saving conatacts
You want to go to Menu->Settings->Accounts & Sync
You'll want to have Background data and Auto sync turned on and then go to your Google id under User accounts on that same page and be sure that Sync contacts is clicked.
From there, you do a Sync Now to force the update you're looking for.
