Help saving everything on my phone
chippy30
Member
I need to take my phone in for repair, (possible new phone) I need to save everything on my phone, i.e numbers, apps and most importantly all my txt messages, is their a simple way of doing this so I can transfer back to my phone if I get it back or transfer to a new phone, please give step by step detail on how to do this
Contacts and texts are easy. My Phone Explorer. Sync them and MPE will have all the contacts and texts on your phone (which you can sync back to another phone).
For apps, just use a backup program that creates apk files. An apk is an installation file for the app - run it and the app gets installed on whichever phone you're running it on.
To save the data grom your apps, Helium should do it. If the phone's not rooted, you'll need to run an app on your PC to get Helium running. The program, running in the phone, will email you a link to the PC program.
right people, I,ve tried but im not really any good at this stuff, can some 1 please put up a easy to follow step by step guide on how to save everything from my phone to a pc or a sd card, and I will also need to know how to transfer it all back to my new phone
Unless your phone is rooted, you can't save "everything" from your phone because some parts of the internal filesystem are only accessible by root.
I use MyBackuPro all the time and while it saves a LOT of stuff, it does not save everything.
