Help Saving "paid for" applications
shmn
Feb 14, 2011
561
330
WA State
Is there a way to save applications that you buy from the market so in case you need to do a hard reset you can get them back? I actually only have one "paid for" application: MLB At Bat 11.
I tried to save it to my SD card but that option is grayed out. How can I make sure that I can get MLB At Bat back if I have to reset the EVO without having to re-purchase?
Why can only some applications be saved to the SD card? And does saving applications to the SD card help you in case of a reset?
BEST TECH IN 2023
Smartphones
