Unfortunately you aren't missing anything. "Scenes" is indeed a Sense thing. Most 3rd party launchers have the option to save/backup the configuration somewhere (don't know about the default launcher in GV, is a year since I used it), but while it saves launcher settings and app icon locations you usually have to replace the widgets - you can see where they are, but they don't usually work.
You could try backing up the current state of the launcher using Titanium - that's about as effective as most launchers' own backups (i.e. not very, see above).
A nandroid backup will of course save it, but that also is a snapshot of the complete state of all of your apps and data, and you can't just reload the launcher configuration.
