Help Saving to SD card
big34dd
I s there a way to save sms, mms, apps,or any other info to sd card on a Fascinate for future reference in case phone gets wiped
try sms backup in the market...i know some people have used it...personally i dont.
your purchased apps are saved to your google account and can be redownloaded for free from the market
if you want to save them with data though you d have to root and get titanium backup.
or if you really want to do it the hard way you can use root explorer navigate to data/app and copy and past the apps to your sdcard.
