M mookie.cs.15 Lurker Jan 29, 2011 #1 Is there a way to save apps to the sd card so that I don't run out of memory as quickly?
HustlinDaily Android Expert Jan 29, 2011 #2 Hey, assuming you upgraded to 2.2. If you go into Settings-->Applications-->Mange Applications. Then hit the Menu Button and select "Sort By Size" Then try to move the biggest ones you can to SD. (select the application then you will see a Move To SD button). Not all apps can be moved, only ones which the app developer allows. Also, do not move widgets to SD because then they will not work. However, there is another method which requires root. There was a thread about it here- http://androidforums.com/acer-liquid-e/234702-acer-liquid-e-internal-storage.html
R rsanciangco Lurker Apr 27, 2011 #3 search on the market "appsaver" so the next time you download apps it will go direct to the sd card.
