Root SBF updated but still the same
D
Deleted User
Guest
I Used RSD to get back to 340. It worked, but radio is still .07 not .12. I used the 434mb file and all was good. What gives? Try again?
that is the correct radio file for .340 it will be updated when you go to GB as part of the upgrade process.
That's good that the SBF file left you with that radio. Doing the 2 part update will upgrade your radio to what you need.
