For Froyo builds like EB01 on these phones the Clockwork Mod packaged with Rom Manager is no longer any good. Do not flash cwm within rm. When you install the SC2.0 through current it automatically has CWM or CWR as I call it(clock work recovery) built in. You never need to download or use Rom Manager like in the past. That's what has happened here. You installed SC 2.6 and then installed Rom Manager and then within Rom Manager you instinctively hit Flash Clockwork Recovery. That's how the newer orange one got there because it does not come packaged with any of the SC Roms. If you do a clean wipe reinstall of SC you will be all squared away. From now on until it changes do not install RM. After installing SC you will have Recovery option in the power down menu. You can also power up holding down both volume up and down to get to recovery, just don't do it through RM.
clockwork 3.0 uses a different type of update.zip script that is not compatible with how our roms/kernels/mods/themes are currently packaged...if you have voodoo recovery flash everything from that (reboot options and 3 button recovery will default to this)
but you can back up the kernel in backup/restore with 3.0 fwiw
