Help Scan and fix SD card?
Anthony2816
When I hook my Fascinate to my Windows 7 64-bit computer and enable the USB connection, Windows pops up a notice recommending that I "Scan and fix" my "Removable Disk".
Is that safe to do? I don't want Windows to change something that'll prevent Fascinate from correctly accessing the SD card...but neither do I want errors on the card.
Saw a similar problem reported in the HTC Desire forum, but no solution was put forth.
I get the same message, i'm just going to copy the contents of the SD card to my computer then do the scan and fix, if i loose anything atleast i'll have it backed up.
