Help Scan for Bluetooth devices missing on ICS?
aikiscott
Folks, I haven't used my Bluetooth headset since I received the OTA ICS upgrade. I tried to pair my headset to my Rezound recently, and couldn't find any commands/controls to do so.
I have found the control that toggles BT on/off, but that's it. On Gingerbread, after you turned on BT, there was a command to "search for new devices" (or something like that), where you could find other BT devices and then pair them (and enter their PIN).
All I can find on my Rezound is the on/off toggle. There is, as far as I can tell, no way to actually pair anything.
What am I missing? Where is the control to have the Rezound scan for devices?
This shouldn't be difficult, but I swear I can't find it.
Thanks in advance!
After u turn it on...hit the menu button at bottom of phone and you'll see it there. If your turning it on under the quick setting menu you won't find it there. You have to go into bluetooth through the main settings menu and then once turned on you'll find it.
