Help Scene Saver Deleted, Help!
DeLaRosa
So I have the HTC Incredible...
My friend was messing with my phone and deleted the "current (save)" feature on scenes and now I am unable to save any scene. I tried getting it back by reseting to factory settings but it still didn't show up. How can I get the scenes to save again?
If I'm reading correctly, you'll have to set your home screens up again, then select one of the default scenes, it should then ask you if you want to save your current home screen, name it, save it and youre good to go. Is this what you're asking? I'm leaving a few steps out thinking you'll figure those little things out.
It just shows the HTC scenes. So I'm missing the my scenes which holds the way to save them.
The way to save scenes is to press the menu button in Settings/Personalize/Scenes as I described (you should get a popup with a Save button). If you can do that, you haven't lost the scene saver (which is part of Sense, so I don't see how it could be deleted), just your old saved scenes. Just reconstruct them and save them again.
I take it back - I've reproduced your problem. Just reboot and things will go back to normal. Must be a bug in Sense.
