Help Scenes and battery life...
Would having different scenes, Say one for show and go and one with no frills make a difference on battery drain between the two or would the inactive scene suck up the precious juice even when not in use? Im hoping to use the no frills on occasion to lengthen battery life.
You'd think a blank scene would use the least battery as it doesn't have any widgets...
I use Launcher Pro, and I set my HTC Sense to 'Blank' then set Launcher Pro as default and rebooted.
I said by to Sense the day I got the phone.
Just remember...some apps have internal sync settings ....ie just because you are not using the widget doesn't mean it isn't refreshing data
